Your rubber air hose is acting as an insulator and the 'wet' air is not condensing on the inside surface. Get rid of the hose and go to copper pipe type "L" Go 2 lengths straight up (24') and put a water trap at the bottom and another when you come back down. This will elininate most of your water problems. Drain your tank daily!!! Also think about getting a larger storage tank, if it runs less, then less water.
