How does the electric choke work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2013, 02:57 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I know current is applied to the choke coil, it gets hot and turns to open the choke linkage.
My question is where does the current originate from? Is it always on once the key is turned on (basically the coil slowly heats up until its 'fully cooked')? If this is the case how do hot starts work? I assume the coil would cool faster than the engine and you would run under full/partial choke after initial start, but also be hard to start in the first place.
Or does it actually use the temp sending unit to dictate the current engine operating temperature? What happens if your sending unit is not accurate or broken?
If it matters I am under the hood of a 1981 C10, no ODBC on this beast.
Old 06-04-2013, 04:08 PM
Banned
<a href="Choke Connection | Holley TV" rel="bookmark" title="Permanent Link to Choke Connection">Choke Connection</a>
Old 06-04-2013, 04:23 PM
OK that was a pretty good video, thanks! I am still curious though about hot starts. Seems like this could be a problem.
Old 06-04-2013, 08:09 PM
WICruiser's Avatar
The power is on full time when the key is on so whenever you turn the key on but do not start right away the choke opens even though the engine is not running. The thermal mass of the system tends to keep the choke warm after the key is shut off to prevent the choke from closing while the engine is still warm.
It is not fool proof and I am sure there can be hot start issues but the carburetor should be set such that when the throttle is fully depressed it opens both the throttle and the choke (at least partially) to allow the engine to start when over choked.
Old 06-05-2013, 03:49 AM
Simple answer - under some hot start conditions the choke will have cooled off at a different rate than the engine and it may cause starting difficulties. However, its usually minor and only lasts for a minute or two.
Bruce
Old 06-05-2013, 04:29 AM
Bruce
I ran into this, especially when I ran my car without a hood. The choke would cool off quicker and further. The cure is as stated above. Turn the ignition switch on for 20 to 30 seconds before you start the engine and he choke will open enough to eliminate any problems.
Old 06-05-2013, 04:35 AM
The bimetallic coil in the choke reacts to ANY heat, not just heat from the electric element. This is no different than a hot air choke. If the engine is warm, or the air temp is high, the choke will be mostly open even with the key off. It also will reach operating temp faster with the key on.
Old 06-05-2013, 04:47 AM
This is why the problem is worse if you don't run a hood. The residual heat is not trapped around the carb under the hood.
In any case I have never found it to be a big issue.
John
Old 06-05-2013, 08:39 AM
John
You are correct, and in reality if you don't run a hood you can tweak the adjustment on the choke coil so it opens at a lower temp.
Old 06-05-2013, 08:58 AM
True Joe. The only issue I had at all was tweaking the fast idle so it worked well at cold start but did not idle too fast if someone ask me to crank it up at the local cruise while the engine was still warm. It was not a problem with the engine loading up or anything. It just interfered with the cool factor. Since I was not running a hood I could reach over and bump the fast idle down by hand.
John
electric choke vs manual choke jrbaker Hotrodding Basics 5 05-20-2013 07:15 PM
Electric Choke 55 CrownVic Electrical 2 02-14-2013 07:16 PM
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 05:14 PM
How does an electric choke work? firewood Engine 18 06-19-2010 07:19 PM
Electric Choke ffcagle34 Electrical 4 08-26-2006 05:37 PM
