How Does the Ford Pull-Out style Overdrive work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2011, 09:11 AM
I have a 1961 Ford Galaxie with a three speed on the column and a "Pull Out" style overdrive unit. How do I activate it and how does the overdrive engage? Thanks.
Old 12-20-2011, 03:48 PM
Overdrive Operation
They are pretty simple compared to modern technology....and Ford used them up into the 70's on some of their trucks.
go to www.fordification.com they have a real nice article explaining how they work. You can also find a wiring diagram at auto-wiring-diagram.com. Once you see the wiring I'm sure you'll be able to figure out what's wrong. Assuming the solenoid is ok and they were pretty tough...it's just a matter of making sure you have power to it.
Old 12-20-2011, 11:05 PM
Wiki Edits: 27
overdrive info
there's info here on HR ,go to the Wiki at the top of this page, then transmissions, then GM and go down to the bottom . some info on overdrives, generic but might help. If you have the T 85 w11 they are strong, it was the basis for redesign to make the Bw T 10.s 4 speeds,
Old 12-21-2011, 06:22 AM
Thanks for the Overdrive Info.
thanks. I'll look at those references just as soon as I can get the gas tank back in and hooked up. The sending unit was leaking. Pulled it out and found that the tank was knarlified. That's a technical word for "all messed up". And, the pickup sock was missing from the pickup. Ordered a new one - should be here maybe on Thursday or Friday hopefully. This car was supposed to be a Christmas present to my daughter. Oh Well.
ford eletronic overdrive monzamadman Transmission - Rearend 6 05-11-2010 11:02 PM
ford overdrive swap claust Transmission - Rearend 1 04-02-2009 01:29 AM
Bellhousing for BOPC to Ford T-85/overdrive Footstomper Transmission - Rearend 0 03-20-2007 12:44 PM
overdrive dont work skelly racing Transmission - Rearend 1 01-29-2007 10:15 AM
Ford Overdrive Automatics for Hot Rods SirSpeedy Transmission - Rearend 3 12-28-2003 12:25 AM
