How does french antenna work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2003, 06:57 PM
ChrisMiddleron's Avatar
Hi yall im just about done stripping the car all down and startin to do body mods. I am looking at the french antenna kits and stuff like that at http://www.bigjims.net/frenchingkits.htm . Im woundering does the antenna pop out of the body of the car? Do you hide it in a tube or something to keep it hidden? How does it get mounted.
Thanks for reading , Chris
Old 06-21-2003, 08:07 PM
BOBCRMAN@aol.com's Avatar
You place the tube in the fender, the depth is up to the builder, the base of the antenna bolts to or thru the bottom of the tube, the object is to have just the antenna shaft showing. The antenna can be manual or power up-down.
Old 06-21-2003, 08:27 PM
willys36@aol.com's Avatar
Wiki Edits: 21
The term "frenched" is a coined adjective used by customizers referring to sinking a car part into the sheet metal. Headlights, taillights, door handles, antennas, etc., etc., etc., have all been frenched over the years.
I guess a French antenna would always be in retreat, come to think of it.
Old 06-21-2003, 11:24 PM
Talking
Thanks guys
