How does a Gen III SBC oiling system differ from Gen I/II systems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2004, 12:37 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
How is the oil pump driven? There isn't a distributor shaft to turn the early style pump. Just curious.
Old 04-09-2006, 02:13 PM
They are putting the oil pump into the timing cover aka 3800 series II and III. It is driven by the crankshaft snout with 2 flats machined and matched to the oil pump. Timing is controlled by crankshaft and camshaft sensors information, sent to the computer, and fires the appropriate ignition coil...Lt1 motors have the distributor located between the water pump and timing cover, directly driven by the camshaft...I'm open to correction on that last fact, by anyone knowledgeable...Hope that answered your question...Cheers!
