How does this happen? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 07:22 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I was coming home late last night and and did some spirited driving. After I got out of it I noticed my volt gauge was only reading 11 so I figured I threw my belt and wasnt that far from home so I kept going. When I pulled onto my street I noticed my volts were at 13 now and I was confused. When I went out to look at it this morning my belt wasn't thrown but had turned on its side and in some places upside down. My belt melted to my alternator as well. How did this happen?
Old 09-01-2008, 07:42 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Something is heating up from a bearing seizing up. Most likely the alternator.
Old 09-01-2008, 07:59 PM
1969NovaSS's Avatar
the alternator is only a month old and its a summit 140 amp. It did through a belt with this alt. before but it only does it if i wind the motor out which I don't do very often. Could I be over spinning the alt. and that could be what is causing the heat?
Old 09-01-2008, 08:02 PM
Wiki Edits: 31
is the belt tight enough? I mean, you should have just a little play in the belt.. but not strung like a guitar string
Old 09-01-2008, 08:32 PM
My 2 cents worth
Wiki Edits: 3
Myself: I would question the belt alignment, pulley alignment..
Old 09-01-2008, 08:35 PM
CustomConspiracy's Avatar
Belt
This is just a guess but if your engine is really built......then that means it really revs FAST, and with all that compression (just guessing) then when you let off it also UNREVS real fast.
It may be that when you come out of it, the alternator has gained so much RPM momentum, that it can't slow down fast enough, and throws just a little slack in the loop.......enough for a twist to form.
As for the voltage drop......my guess is on the rev side of it.....the motor is reving so fast that it spins the belt......causing the voltage drop and also putting a LOT of heat into the belt.....which would also EXPAND the belt and maybe make for just a little slack even if it seems properly adjusted when it's shut off.
BUT it's probably just a bad bearing.
Old 09-01-2008, 08:38 PM
4 Jaw Chuck's Avatar
You flipped the belt, usually happens with non-deep pulleys when you turn some serious rpms.
You will find you must keep an eye on your belt tension more often and tighten a little more than usual compared to a low rpm daily driver, its the nature of the beast.
Old 09-01-2008, 08:42 PM
1969NovaSS's Avatar
It looks like its lined up fine but it may be deceiving me. I was thinking of installing a z/28 deep groove pulley. Its not very expensive and NPD is just down the street from me.
Old 09-01-2008, 08:49 PM
1969NovaSS's Avatar
Well the frist time it through the belt was at 7k in first gear and this time it only saw 6k or so. Its no high comp motor. Its been my daily driver for almost 4 years now.
Old 09-01-2008, 08:56 PM
My 2 cents worth
Wiki Edits: 3
Another thought, may be way off base, but do you have a body ground hooked to the "negative" battery post? This can cause a voltage "over load", (not hooked up) in the charging system.
Old 09-01-2008, 08:59 PM
1969NovaSS's Avatar
I have the main cable attached to the head and the smaller cable attached to the fender. I never had a overcharging problem more of a under charging problem with my stereo and fan on .
Old 09-01-2008, 09:05 PM
I'd say your heavy electrical load is causing the belt to slip on the alternator pulley.
A lot of high performance cars had larger alternator pulleys to slow the rpm... of course, this hurts low rpm charging.
You would be way ahead if you could convert to a flat belt. Kits are available.
Old 09-01-2008, 09:17 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I have the answer. What do I get if I'm right?
I'll bet $5 that you have a pretty pulley; polished aluminum or chrome? They consistently don't grip the belt. You'll notice inconsistent voltage depending on the belt's temp, but the one thing you will always notice is a screaming hot pulley and sometimes a melted belt.
I work at a custom shop and every time like clockwork the customer asks for a pretty pulley, and every time I have to sand the groove of the pulley. If I forget I always get 11-12v and a nice burn on my hands when I investigate the pulley. Left alone, the belt will go in and out of times when it grips and when its either melting or slipping.
The other likely possibility has been mentioned; high RPMs and either slightly misaligned pulleys or a slightly loose belt could have caused the belt to flip which will melt it as well.
Old 09-01-2008, 09:32 PM
1969NovaSS's Avatar
Yes it is a chrome alt with a chrome pulley only because it was more expensive for a painted one. I have no problem getting 14v at idle and if the belt isn't tight it will scream when the fan comes on. Ill take that pulley off and buy the z/28 and see what happens.
Old 09-01-2008, 11:10 PM
curtis73's Avatar
Wiki Edits: 16
Easy fix, then.
Take the belt off, take a folded piece of coarse grit sandpaper (maybe somewhere between 150 and 80 grit) and scuff up the groove. Seriously, it doesn't need to be much. If you spend more than 5 minutes on it you spent too long Just break the glaze that's all you need.
How did this happen? EazyDuzIt102 Engine 49 10-17-2005 11:35 PM
what would happen if i didnt pay? happycamperbus General Rodding Tech 46 03-23-2005 06:23 PM
how would this happen?!?! red_rider52 Transmission - Rearend 12 01-18-2005 10:23 AM
Anyone had this happen??? ets1945 Hotrodders' Lounge 12 03-31-2004 09:40 PM
