How does Humidity affect a/r ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2005, 01:14 PM
trenchdog73's Avatar
J Smith
How does Humidity affect a/r ratio?
Old 08-04-2005, 02:17 PM
brainsboy's Avatar
brains
I believe the only effect would be on the density of air. As humitity go's up the air becomes less dense. It may be a better question to ask how air density effects a/r ratio.
Old 08-05-2005, 01:27 PM
It will richen the mixture so you'd need to jet down. The water vapor molecules take up the space normally occupied by the air molecules so the mixture will go fat. The dryer the air the leaner the mixture, given constant jetting.
max compression ratio on 89 octane gemini86 Engine 31 07-01-2005 03:35 PM
Can I use 1.6 ratio roller tip rockers? Houman SS '70 Engine 53 05-13-2005 01:04 PM
What is the maximum humidity for painting? BondoKing Body - Exterior 12 05-11-2005 04:26 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
High compression ratio pistons invincible Engine 6 09-22-2003 10:16 PM
