How does a mechanical voltage regulator work? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-16-2011, 07:24 AM
Wiki Edits: 27
automotive electrical
I still have my Text book from the 60's, You can adjust a regulator for a generator by either turning adjusting screws or bending the contact arms.spring tension . polorizing a generator..the terminals you jump depends on internal wiring It is not the same for all units. and there is a cut out relay that prevents the battery from trying to make a generator a motor.
  #17 (permalink)
Old 11-24-2011, 03:45 AM
A regulator is a nonohmic element and its response cannot be adequately described in terms of resistors.
There is no fundamental effect on electrons, they continue to flow through wires like always.
Just a Dead Battery? 1quiknova Electrical 7 06-07-2006 07:04 PM
*glossary Of Basic Electrical Terms* docvette Electrical 2 04-28-2006 07:27 PM
Mechanical Advance MSD 8360 Mertz Engine 1 09-19-2005 02:10 PM
427 or 454? frankenvette Engine 50 06-05-2005 10:12 PM
Distributor infinite mechanical advance Tabdown Engine 9 03-11-2005 07:02 PM
