How does my old cam look? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-18-2008, 04:54 AM
v8hed's Avatar
AK427
No real conclusions. All I know is that when I posted pics of the wear surfaces of the lifters on here, folks told me my cam was 'junk'. In fact, several folks told me I needed to pull the engine and rebuild it! Well, I'm not going that far... I'm installing a new cam and lifters and I'm gonna see how it goes.
  #17 (permalink)
Old 07-18-2008, 07:19 AM
It doesn't look like it should require a rebuild yet. If a lifter had become severely concave and a cam lobe obviously rounded off, then I would say you need a new set of bearings and some crank work at the machine shop. But it looks like the lifters and cam were just starting to go bad.
During you next break-in try using only one valve spring and maybe some reduced ratio rockers. Plus use an oil with a lot of zinc and use break in oil additive.
Furthermore, you may want to consider getting the cam hardened and maybe use those lifters with that little oil hole on the bottom. And use a cam that doesn't have really aggressive ramps, so don't use "voodoo or xtreme" cams.
I did see a lifter picture on one of your other posts. And it was on the way out. It was the one with a line wear pattern. Wear patterns on the lifter should be circular. That lined lifter was about to go concave and round off the lobe.
  #18 (permalink)
Old 07-18-2008, 07:25 AM
v8hed's Avatar
AK427
Well, I've taken the calculated risk of getting an XE274 cam + good quality Sealed Power lifters. Will be using ZDDP+ in the oil and a moly disulphide cam lube. Hopefully, all will be OK.
That 'lined' lifter was just an oil mark (if you're referring to the pic with the brown mark on the lifter face).
  #19 (permalink)
Old 07-18-2008, 07:58 AM
The line looks like a burnt mark, but glad to hear it was just an oil line.
Good luck with that cam! Remove the inner springs if you have dual springs. Look into getting a set of reduced ratio rockers for the break in. I'm sure you will be able to use them again for another engine.
  #20 (permalink)
Old 07-18-2008, 02:07 PM
what are reduced ratio rockers? the rockers I run are 1.52's.. I didnt think you could get any less that 1.5's or such.. ive had cam issues in the oast with break-ins and thats with using ZDDPlus, VR-1 oil and coating the H*LL out of the lifter bottoms and cam lobes with the paste that comes in the cam / lifter sets... im to the point now of having my block drilled for a spider plate and installing a roller cam / lifters and using a button!...
-Christopher
  #21 (permalink)
Old 07-18-2008, 08:56 PM
4 Jaw Chuck's Avatar
Looks 100% perfectly normal to me. Throw it back in,,,don't mix up the lifters.
  #22 (permalink)
Old 07-19-2008, 06:39 AM
Originally Posted by ImRoyaltyInMyChevy
what were the condition of the cam bearings?
because I got a motor with low mies but the cam looked like your but a little worse and the bearings were just totally grooved, chipped, and carved lol I wanted to know if it happened to you because we both know we had a bad break in but would that usually also cause the bearings to go bad to like from to much heat or no lubrication? or this is just because my oil pump got plugged or something, but my main bearings were pretty nice. how were the rest of the bearings in your engine?
We just had an engine come in the shop a few weeks ago with spent cam bearing from another engine builder using stock cam bearings with a hyd. flat tappet cam.
We don't put stock cam bearing in any of engines we build and we never see these problems. For another 6 or 8 dollars its well worthe using a set of CHP-8 or we use the ACL 3349 cam bearings and never look back.
Here is an old link to look over on performance cam bearings and I guees I wasn't to far off HMMMMMMMMMMM And its hard to believe that some engines builder cry about putting in good cam bearing.
chewed cam bearings?
Debating stock vs performance cam bearings
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
