How does one install crank hub bearing support - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 12:34 AM
Hi, trying to install very long crank hub but is too long for standard install tool plus the center diameter of the captive washer that is welded in place is too small to accept the tool. Im thinking to drill it out but not sure if that would be a problem. Thanks for any help at all.
Old 07-19-2011, 03:45 AM
Clint Cummins's Avatar
Yeah,
Drill it to fit the larger bolt.. try not to get your hole off center.. no matter how slight.
Are you sure the longer bolt you will be using properly fits the crank snout?
Does this help any?
crank bearing fatboytruck Engine 6 04-22-2011 04:43 PM
steering shaft support bearing location. Prof. T. Soggmeyer Suspension - Brakes - Steering 4 06-13-2008 06:50 AM
Driveshaft center support bearing ? markzepp820 Transmission - Rearend 24 07-15-2007 06:52 AM
SBC Crank bearing specs? Gearhead forever Engine 5 06-15-2005 11:15 PM
Pilot bearing install Zeder Transmission - Rearend 2 11-14-2004 04:09 AM
