How does this spark plug look? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-25-2010, 11:48 AM
Originally Posted by Dajerseyrat
See how the difference in opinions on the color of the plug vary...I would invest in a nice Widband O2 sensor like a Innovate brand, or AEM...These will allow you to bring a laptop to the track and log the pass in real time, then go back and look at the data of the A/F..
I personally like my pump gas N/A cars in the 12.5-13.0 range for power and safety..
I see that, it's like everyone has a different opinion on what the ideal plug should look like ha. I will eventually buy an WB o2 when I get some money, but right now I'm stuck trying to read plugs and timeslips.
  #17 (permalink)
Old 07-25-2010, 12:18 PM
automotive breath's Avatar
Your plug heat range looks a little too cold
read plugs
"The white porcelain does not indicate jetting !! Do not look at the porcelain
insulator for jet changes ... instead look at the plug's base ring"
  #18 (permalink)
Old 07-26-2010, 12:30 AM
I've seen those pictures before, but not sure if they're good to go by or not. I can't get any color at all on the threads base ring.
  #19 (permalink)
Old 07-26-2010, 04:11 AM
Mopar or no car.
I read about a cheap way to make a O2 setup.
You get a Normal O2 sensor, then hook a multimeter up too it, and use the voltage to tell you were in the A/F range you are.
  #20 (permalink)
Old 07-26-2010, 04:13 AM
Mopar or no car.
  #21 (permalink)
Old 07-26-2010, 09:49 AM
Does that really work? like a wideband? I know I'm in the ballpark. Now I'm just trying to fine tune.
  #22 (permalink)
Old 07-26-2010, 09:54 AM
Mopar or no car.
I would think so. I have a feeling a pre-built wideband uses normal o2 sensors.
I read about it here- http://www.bob2000.com/carb.htm
changing plugs?on a V10 ford?how!? bonzipenguins Engine 23 06-03-2009 06:29 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Spark Plug brands question Francis Engine 65 07-15-2008 12:01 AM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 04:54 PM
Weird spark plug situation?? Jim Weeks Engine 4 05-13-2002 07:32 PM
