How easily should my engine turn over? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2012, 07:33 PM
I am doing my first rebuild and it is a gen 1 350. I was wondering how easily my engine should turn over with just the cam, crank, chain, and pistons. As in turning the crank bolt with a clicker torque wrench.
Thanks
Willy
Old 02-02-2012, 02:41 AM
reply
first, never use your clicker torque wrench, there to expensive for that, use a breaker bar or long handle ratchet, second, put a little oil in the cylinders so there not dry and you should be able to turn it over with a mild resistance,
Old 02-02-2012, 05:45 AM
engineczar's Avatar
Continuous turning not break away with standard rings probably in the 30-40ft/lb range. I've had it under 15ft/lbs with thin rings and low tension oil rings.
BSE Racing Engines
1979 Trans-Am set for years, now does not move easily 79TA-sandro Transmission - Rearend 11 04-22-2011 06:01 PM
PPG Omni scratches easily ScoTFrenzel Body - Exterior 7 10-26-2008 01:47 PM
Is this bumper easily repairable dnwong Body - Exterior 7 04-17-2008 08:19 AM
not for the easily offended crshrmn3 Hotrodders' Lounge 3 12-16-2002 04:40 PM
Find it yourself quickly and easily jenkinra Hotrodders' Lounge 1 04-30-2002 12:43 PM
