Actually I would use the hose and fittings from aeroquip as the hose ends are reusable and those guys know hose and fittings..another one of those things that is easy if you know how..
www.aeroquip.com Sam
I saw the tool on TV - pretty cool (Koul?). I would use it if I could borrow it for the afternoon - but wouldn't put the money out for a single project. The most difficult part of the stainless hose assembly is probably cutting the hose which doesn't involve the new tool anyway. Nothing really difficult in assembly the pieces. I cheat by using an air grinder cutoff tool that makes a fairly smooth cut, and if I have problems with starting the fitting in the hose, I bevel the inside edge of the hose with a die grinder to give me a head start. One thing that I wished I had purchased were the AN wrenches because no matter how careful you are, your're going to mar the anodized finish if you use standard wrenches. The assembly is goof-proof and after one or two fittings, you'll feel like an expert.
| Braided tranny lines and dipstick? | Rubberman2003 | Transmission - Rearend | 2 | 01-28-2006 03:11 PM |
| Best Rust Inhibitor? | bigbrowndog | Body - Exterior | 45 | 11-21-2004 08:26 PM |
| How flexible do cooling lines need to be? | McDeuce | Transmission - Rearend | 3 | 03-22-2004 12:36 PM |
| -AN fittings on transmission cooling lines | jamnut | Transmission - Rearend | 3 | 07-14-2003 11:07 AM |
| Problem getting fittings on braided steel lines | Mr.56Chevy | Engine | 4 | 05-20-2003 09:17 AM |
