How to eliminate kick down cable on th350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2003, 10:47 AM
Post How to eliminate kick down cable on th350?
How do i take off the kick down cable. I no longer have it hooked up and i would like to take off the cable. Is there a short cut in doing this?
Old 02-19-2003, 02:48 PM
DoubleVision's Avatar
Post
unbolt it from the tranny, then use the end of cable that bolts on, cut it, fill it with sealant but not all the way to the bottom as the lever in the tranny rides inside the cable boot slightly, then bolt it back on, is what I did to mine.
