How to Emboss Lettering into Sheet Metal - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 11-02-2011, 05:19 PM
Originally Posted by Art Deco
What about the thickness of the sheetmetal vs the thickness of the urethane sheet? What would you suggest?
I used 24 gauge steel for the letters pressed into 20 gauge steel for the panel. 1/8" 90D polyurethane was what I had on hand and it worked fine. I also tried some 75D and 60D but the harder stuff made the impression more crisp.
I considered using a wheel but was concerned the localized pressure would warp the panel. It might have worked out ok, I just didn't try it.
Tom
  #47 (permalink)
Old 11-04-2011, 11:24 AM
Originally Posted by Figbash
Tom
How did the "A" letters get embossed in backwards on the trunk when your blank has them the correct way?
  #48 (permalink)
Old 11-04-2011, 11:33 AM
The "A" got embossed backwards because the numb skull doing the work stuck it on backwards. The actual piece in the trunk was a later iteration.
Tom
  #49 (permalink)
Old 11-04-2011, 11:40 AM
That's a bummer.
I am a retired sign painter so when I see misspelled words, mixed fonts or backwards letters it's like fingernails on a chalkboard for me.
Cool idea though and otherwise well executed.
  #50 (permalink)
Old 11-04-2011, 02:28 PM
Last journal entry: V/W Outboard
Embossing
This is Good.
About five years ago I had a 64' FORD Econoline P/U.
Tail Gate was gone and I had a PEPSI COLA sign
with Raised (Embossed Leters). Curved It to Fit,
Welded, Smoothed and
WOW it looked Great. Then had to get into other
PEPSI stuff for the Truck.
Lots of Coments.
Bob
  #51 (permalink)
Old 11-05-2011, 11:08 AM
Im trying to have an idea!
thanks for posting this. i was thinking of doing the same think but with the emblems of the car.
  #52 (permalink)
Old 11-06-2011, 09:52 PM
I use a similar process for making holsters and sheaths, that can be applied to dashboards and door panels using thermoplastic panels. The only difference is you would be using the plastic over the letters or emblem and lay a plate covered with a stiff foam over the plastic panel after carefully heating it with a heat gun. carefully press and the shape becomes a positive emboss in the plastic. This is how Kydex sheaths and pistol holsters are made. To do an impressed emboss the foam is put down and the emblem or letters are placed on the heated plastic and a plate layed on it/them and pressed. On a positive emblem in plastic like this remember to fill the backside with bondo for strength, so the letters are not crushed in like a dimple on a McDonalds soft drink lid... I'm going to try the metal setup on some signs... EXCELLENT Thread. I never thought of trying this with metal. I've done it with Leather as a kid working on his leathercraft merit badge in boy scouts, made knives and sheaths like I've outlined (always use a molded replica for the form), never once gave metal a thought... amazing... And I ran a punch press at one time while in college,,, DUH!
  #53 (permalink)
Old 11-07-2011, 07:23 AM
Embossing
Dragon; You might try Vacuum.
Rather than using a Plate , Clamp a oversize Pc of plastic
to a Board with any shape. Place Text or Logos where you wish.
The plastic will need to be clamped all around to get somewhat of a seal. Use your shop vac, and a Heat gun. This works great.
I have made Deep buckets, Lids, Signs, and ETC.
For deep moldes, Wood is good, but you need to Have a reliese agent.
Mix Silicone Caulk with Mineral Spirits in a 50-50 mix. Paint with a brush.
This will Seal and smoothe. It will dry, but requires a few coats.
To remove the part, apply a little heat and reverse the vac.to blow the part off.
Have Fun
Bob
  #54 (permalink)
Old 11-24-2011, 09:07 PM
vac vs press
Vaccum shaping works on many things (I've used it) however, using a press requires much less overlap, and therefore generates less waste that needs to be trimmed off. It all depends on the project at hand. As you noted, it works great on deep molds.
None the less, Thanks for the comment, The more we get this info out to everyone the better!
D
  #55 (permalink)
Old 11-24-2011, 10:03 PM
wwilliams181's Avatar
LOL!! i didint even notice the "A".. Super Job though..
sheet metal camarossrs56 Introduce Yourself 4 08-22-2007 07:48 AM
sheet metal ? jackodom Body - Exterior 2 04-28-2007 05:57 PM
new sheet metal seaswirl Hotrodders' Lounge 2 09-06-2006 07:00 PM
Where to buy Sheet metal cab Body - Exterior 12 07-25-2006 07:38 PM
sheet metal help?? gmthomas44 Hotrodders' Lounge 2 09-17-2002 09:53 AM
