how far apart/how many plug welds should be on the bottom flange of this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2012, 08:00 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
I have the piece of sheet metal that goes on the back of this patch panel ready to go
what is the standard for the distance, on the plug welds, that will go across the bottom flange?
1", 2", 3" apart?
then what? should I put some seam sealer on the inside?
Old 01-07-2012, 08:12 PM
poncho62's Avatar
Wiki Edits: 5
I used to spot weld in an auto plant...We were supposed to put a weld every inch or so.......
Old 01-07-2012, 08:24 PM
& matts38chev
the other pieces inside, above that panel, I punched the holes 1" apart
it seemed kinda close together, and I didnt know if I was going to weld all the holes or every other one
however, more is better than less
Old 01-08-2012, 06:40 AM
deadbodyman's Avatar
Wiki Edits: 11
I usually do them by eye ,whatever the factory did on that particular car.
Old 01-08-2012, 08:23 AM
& matts38chev
that part was rotted off , so I dont know what they were spaced at
Old 01-08-2012, 09:17 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If its just a inside cover panel and not use for strength ever 2-3 inches should be fine.
Old 01-08-2012, 10:38 AM
About an inch to an inch and a half is standard. Look on the other side, or on some other area that isn't rotted away and you can see what they did there. But honestly, an inch to an inch and a half is pretty standard. Other than putting them four inches apart or a half inch apart you can't screw it up.
Old 01-09-2012, 08:23 AM
Wiki Edits: 11
Matt,Just to be clear ....spot or plug welds are only used on the perimeter to fasten the panel to the inner structure...If you did a repair to the inner structure itself by replacing a section , the seam should be a continuous weld ,then epoxy primed....just like doing a repair on the body skin ...there should be no need for a body sealer if there wasnt any there before...
Old 01-09-2012, 09:17 AM
& matts38chev
this was just to attach the piece behind, it across the bottom
there are 2 pieces behind it, one goes down and one goes up
I ended up going 1" apart
this part of the build (sheet metal etc.) has been making my brain hurt
I want to make sure I do it correctly, so I wasnt doing any of it, because I didnt want to screw it up
I have now decided, I dont care anymore, I am just going to do the best I can, and it just doesnt matter
I'm going to slap this thing together and drive it
I'm sure I'm doing parts of it wrong, but thats going to be someone elses problem, after I'm dead
thanks for the help, with the answers, guys
and any future info I might need
ALSO, IF ANY OF YOU GUYS, see me getting way off course in any of the pics.
PLEASE SAY SO, you wont hurt my feelings
ID:	61624   Click image for larger version
ID:	61625   Click image for larger version
« primers | westside »
.023 and .024 welds chase1994 Hotrodding Basics 4 06-18-2009 11:54 AM
Distance between plug welds modas Body - Exterior 3 06-16-2006 07:31 AM
Plug Welds upside down pschana Body - Exterior 11 09-20-2004 09:28 PM
9" Housing Flange to Axle Flange 68NovaSS Transmission - Rearend 2 10-14-2002 02:32 PM
i need to find out the length of my rearend, axle flange to axle flange tony350ss Transmission - Rearend 2 10-03-2002 02:15 PM
