-   -   how far can u turn down a eagle crank (http://www.hotrodders.com/forum/how-far-can-u-turn-down-eagle-crank-179904.html)
millertime0372 06-22-2010 10:49 AM
a friend of mine gave me a eagle crank that came out of his 555. it has spun bearing on it. i was wondering how far i could have it trun b4 it became un safe to use.
lmsport 06-22-2010 12:34 PM
the strength loss by grinding is minimal 'IF' the proper radius is maintained. There will be a loss of hardness but that is not an issue for most applications.
millertime0372 06-22-2010 07:09 PM
ok thank u
BOBCRMAN@aol.com 06-22-2010 08:15 PM
It is common to turn these BBC cranks to small block size rod journals. Bearings for small block rods are available to .060 undersize. Big block mains are good to .040 undersize..
