how far can u turn down a eagle crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2010, 10:49 AM
a friend of mine gave me a eagle crank that came out of his 555. it has spun bearing on it. i was wondering how far i could have it trun b4 it became un safe to use.
Old 06-22-2010, 12:34 PM
the strength loss by grinding is minimal 'IF' the proper radius is maintained. There will be a loss of hardness but that is not an issue for most applications.
Old 06-22-2010, 07:09 PM
ok thank u
Old 06-22-2010, 08:15 PM
BOBCRMAN@aol.com's Avatar
It is common to turn these BBC cranks to small block size rod journals. Bearings for small block rods are available to .060 undersize. Big block mains are good to .040 undersize..
Eagle or scat crank?? what would you use? tiresmoke55 Engine 24 08-31-2011 11:05 PM
First Start Up Problems 1974blackz28 Engine 27 05-24-2010 10:00 AM
78 camaro turn signal help hcker2000 Electrical 16 06-15-2007 04:06 PM
Serious problems removing harmonic balancer! spyderdude Engine 55 06-09-2005 10:01 AM
Rebuilt engine won't crank. lt1bbody Engine 10 04-22-2005 12:44 PM
