How far should front shocks be compressed with wheels hanging? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2012, 11:17 AM
jamieson's Avatar
The title pretty much says it all. My front suspension is finally in, I just need to add upper shock mounts. What percentage of the shocks travel should be compressed when the frame is supported and the wheels are hanging? Shocks are Bilstein, if it matters.
Thanks!
Old 03-25-2012, 03:20 PM
blwn31's Avatar
Ok I'll bite, none. The shocks should be fully extended.
Keith
Old 03-25-2012, 04:35 PM
jamieson's Avatar
I figured I would need something like 5 - 10% compression to keep the shock from bottoming out if my front wheels ever come off the ground... I guess that wont happen though due to the slow expansion speed of a (functional) shock. Also, since I have never opened up a shock and looked inside, I cannot really say if "bottoming out" is a real problem.
Thanks for the reply!
Old 03-25-2012, 06:49 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i think you are correct
i would leave a small amount of travel
you dont want the shocks to bottom out on either end
front shocks for 23T tanman10069 Suspension - Brakes - Steering 10 09-01-2010 04:46 PM
front shocks question gilliganspl Suspension - Brakes - Steering 3 08-10-2006 08:28 PM
Front Shocks stickshift Suspension - Brakes - Steering 2 12-22-2004 07:28 PM
front brakes are hanging up.1979 camaro mycarsz28 Suspension - Brakes - Steering 1 10-12-2004 06:18 PM
56 f100 front shocks tri 5 ernie Introduce Yourself 1 08-30-2004 11:10 AM
