How far should my fan be from the Rad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 09:59 AM
wickster's Avatar
Having some cooling issues with my car....factory shroud and 4core rad...I am wonderiung if the fan is too far from the rad?
How far should the front face of the fan be from the back of the Radiator. Mine measures about 4" and there is a 1 1/2" space between the water pump and the fan.
Old 06-05-2007, 10:08 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Ever taken a good look at the fan and shroud on a 1st Gen Monte Carlo? The fan is a mile from the radiator. I'd position it so the center of the blades are even with the back edge of the shroud or as close to that as possible, that's always worked for me.
Old 06-05-2007, 10:56 AM
Jmark's Avatar
Yep, fan half in and half out of the back edge of the shroud. Also make sure your fan clutch is working properly. It should free wheel when the engine is cool and should spin up hard when the radiator gets hot.
Most fan clutches today suck, even when new. It took me 4 tries to get one that actually did what it was supposed to. I ended up with a used one off a mid '80's truck! Works just like it's supposed to.
Old 06-05-2007, 01:20 PM
wickster's Avatar
OK. Guess I will take out the spacer then....
Old 06-17-2011, 12:49 AM
We have always done the half in half out method with our fan schrouds too. We race 80s models monte carlo that are gutted out to nothin but frame and body. We sometimes build our own fan schrouds so it is key at where you place the back edge of the schroud in alliance with the fan blades because these cars are turning some rpms. We race on dirt oval tracks in southeast texas, and overheating is easy to do.
Old 06-17-2011, 01:15 AM
SSedan64's Avatar
The factory Chevelle shrouds aren't much of a Shroud. Just a thin Metal ring with open side areas.
Name:	64-65 Chevelle Shroud (Small).jpg
Old 06-17-2011, 11:01 AM
A cooling problem that is where in the duty cycle? That at idle, on the road, or everywhere?
At idle would indicate insufficient air flow. On the road or everywhere is usually a either a flow or a capacity problem, or a component failure, or a plumibing routing issue.
Bogie
Old 06-18-2011, 12:07 AM
DoubleVision's Avatar
This thread is 4 years old.
Old 06-18-2011, 06:09 AM
I wonder if he got it to work.
More updates/end results would be nice around here.
Old 06-18-2011, 11:13 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Opening an old thread isn't a bad thing IF you have something constructive to add. But opening and posting something that's already been posted just to make noise makes no sense.
Semper Fi
Rad fan switch?? Scrumgees Engine 7 07-04-2006 09:49 PM
fan against rad or leave a space? smlblcks10 Engine 11 08-03-2005 06:51 PM
Aluminum Rad or Home made fan shroud? sandiegopaul Engine 18 06-14-2005 02:10 PM
belt driven fan to rad clearance problem jcarter Engine 8 12-24-2003 12:03 AM
rad fan attachment? 34Plymouth Engine 5 02-17-2002 03:05 PM
