The slip yoke uses about half, if the yoke is 6in the out put shaft goes in 3in. I am planing on using a chevy 350 to a ford 9 and can have the drive shaft made with the two different sized u joints. There is a trick to measuring for the drive shaft. For instance take measurements at ride hight. Try a web site for custom drive shafts, they usually will tell you how to do this even allow a doc to download for your own reference. I am sure you could find a local shop, preferred with specs. in hand will do a nice job for you.
Do you have a local drive shaft company? If so, give them a call and ask them for their suggestions. I know that are "some" u-joints with different caps for certain popular applications/swaps. Also, the "slip distance" can differ some depending on rear end travel, but usually, 1" out from fully seated into the trans is a safe bet.
| TH350 driveshaft yoke leaking | Jmark | Transmission - Rearend | 11 | 08-16-2008 11:38 AM |
| Slip yoke question | Leaky Pipes | Transmission - Rearend | 2 | 05-24-2007 04:59 PM |
| Slip yoke question | Leaky Pipes | Hotrodding Basics | 3 | 05-24-2007 05:06 AM |
| Grooved slip yoke | chrias | Transmission - Rearend | 1 | 08-12-2004 11:25 AM |
| Installing a slip yoke trans with a two piece d-shaft | Jason | Transmission - Rearend | 8 | 11-27-2003 01:49 PM |
