how to fill holes in butterflies? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2009, 03:26 PM
Hi
I have a Holley 600 with a small hole (2.5 - 3mm) drilled in each of the front butterlies. I was going to solder them to day when I noticed they were steel not brass. Thought about puting a small brass nut and bolt in each hole and dropping some solder on the nut in order to lock it and prevent it vibrating loose and touring around the engine! Any suggestions about filling them in please?
Thanks
Old 03-30-2009, 03:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will no doubt head "JBWeld it." I'll only say that JBWeld will loosen over time- seen it too many times when I used to use it to cover the main jet wells of Q-Jets.
Solder WILL stick to steel. It takes acid flux, careful tinning and a hot iron. You will want to use silver solder.
I think the best way (besides never drilling it in the first place) is to braze them. You will want to oven heat the entire blade. Then quickly, but carefully play a relatively narrow flame- like from a jeweler's torch- over the hole while feeding pre-fluxed brazing rod into it.
If you go w/screws and nuts, don't depend on anything except mechanically upsetting the threads that protrude (slightly) through the nut. Look at how it's done on a Q-Jet. They split and flare the ends of the screws so they can't fall into the intake. Same kind of deal, except add a nut to the equation.
EDIT- The oven heating is with the blade removed. Less or no heat if still in the throttle body, but you prob. knew this anyway.
Seriously consider soldering it if you can get a good, hot Unger, etc. iron.
Good luck.
Old 03-30-2009, 06:42 PM
4 Jaw Chuck's Avatar
You need that small hole, why are you trying to fill it.
Old 03-30-2009, 09:02 PM
why do i need those small holes. There is absolutely no idle adjustment on the throttle stop screw. the throttle closes on the butterflies and still races to 1200 when hot so when you engage D at the lights youve lunged forwarss like youre leaving the line on the 1/4 mile. and for stop start traffic its a nightmare. With the holes pluged throttle screw is about 3 turns in and she idles at 800.
I cant remember why my mate drilled them in the first place
Thanks so much for all your input
Old 03-30-2009, 11:46 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Uh... new throttle plates are like $5. No need to fill the old ones with questionable methods, just get new ones.
Old 03-30-2009, 11:52 PM
New ones....that would have been like the first thing to think of. He is in the UK though, don't know how available they might be over there.
Old 03-31-2009, 12:19 AM
curtis73's Avatar
Wiki Edits: 16
Oh... easy then. If you don't have access to someone who can braze it (nice neat solution) scuff up the plates with some 1000-grit paper on both sides. Tape off the bottom of the holes and then push the tape down just enough to pull it away from the surrounding area. Then fill it with epoxy. You don't want something like a nut and bolt obstructing or changing flow.
Epoxy like this:
Name:	throttle blades.JPG
Old 03-31-2009, 01:32 PM
I used electrical solder on my holley blades and it has been working for a few years now.
Old 03-31-2009, 01:45 PM
if i put new throttle plates in how do i split / flare the ends of the screws ?
Old 03-31-2009, 01:51 PM
you don't. just use lock tight on the screws.
when you take the throttle shaft out, grind the end of the bolt flush with the shaft, and remove the bolt and plate. Use lock tight when you put the bolt back on.
Old 03-31-2009, 02:48 PM
Originally Posted by neverending
Hi
Thanks
First off, what engine is this attached to? The use of a hole in the butterfly is there to address idle air needs with a long duration cam. These require a fast idle which to get would, without any other compensation, require opening the throttle blades to a point where the transfer slots become exposed. This causes an excessively rich idle that you can't control with a huge bog before main-metering kicks in. The holes in the throttle blades were put there to allow extra air the engine needs without having to open the throttle blades so far as to expose the transfer slots.
So before you modify the carb, the first question I have is, what is the cam so as to determine whether the holes are still needed.
Bogie
Old 03-31-2009, 09:12 PM
Its onlya goodwrench crate engine 290hp with a mild street cam. I have asked the dealer here in the uk untill im blue in the face what the cam is. He doesnt know, he just ships theses motors in from mexico. Given only 2 choices. a huge bog or 1200 idle in an auto I will have to live in a bog! or try a deamon carb????
Old 04-01-2009, 12:09 AM
Have you adjusted the rear butterfly stops closed, they may be open.
Old 04-01-2009, 03:42 AM
Originally Posted by F-BIRD'88
The 260hp GW crate motor uses a stock SBC cam 195-202 .390 .410 112
The 290HP GW motor uses The old GM L-46 350-350hp --L82 cam
222-222 .450-.460 114. Sucks in this low compression motor.
A simple cam swap to something with 204 to 212@.050 duraion is a nice improvement. Drilled throttle blades mod is not required on this motor.
Thanks for the info. Can you elaborate a little on why it 'sucks' please. Also you use the words simple and cam swap in the same sentence. Whats involved in swaping the cam?
Old 04-01-2009, 05:06 AM
What is your timing set at? Are you using ported or full vacuum advance?If the timing is to far advanced it will idle fast.Also if using full manifold vac to the advance try hooking it to a ported source see if this helps with your problem.
350 Chev head gasket water holes too small? rlmfire Engine 7 04-14-2007 08:11 PM
Plugging holes in 32 frame rails heyjude076 General Rodding Tech 5 01-25-2007 08:00 AM
Using Muggyweld/lead for pin holes Slickriffs Body - Exterior 2 10-01-2004 09:07 AM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 11:55 AM
How to fill holes? and other questions Andrew7dg Body - Exterior 7 07-24-2002 08:39 AM
