how to find p0440 leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 11:46 AM
I have a 1999 silverado 1500 6cyl, and have had a p0440 code for about 4months now. i changed out the gas cap but no luck. whats the easiest way to trace out this evap leak code? thanks
Old 02-19-2012, 02:26 PM
Smoke machine.
Old 02-19-2012, 02:42 PM
LATECH's Avatar
Smoke machines arent as good as they are made out to be. They wont show a leak in a canister purge valve or most small leaks, as the leak is small so may be the output of the smoke, and it can precipitate before it gets close to the leak.
I would pull the purge valve and look for carbon canister debris( carbon media ) in it. It is a known fact that GM canisters have an issue with the carbon getting loose and being sucked up into the purge valve.If you see it in the valve or not, disconnect both ends of the line and blow it out, look for the carbon media when you do.carbon media will require canister replacement after repair/ replacement of the purge valve
Also canister closed valves can get water intrusion into the filter and the dirt can embedd itself in the plastic plunger of the valve and cause it to stick, either intermittently or consistently, not closing setting the code when the diagnostic monitors run.
Look at the filler neck real good first, I have seen many rusty ones and some have holes in them, causing the issue you have.
Oil Leak---for The Life Of Me I Cant Find It :( chevyrestore Engine 6 09-12-2011 06:06 PM
Chevy 350 oil leak. Can't find it. seawolf18 Hotrodding Basics 6 09-12-2011 04:30 PM
Cant find my vacuum leak.. stroker444 Engine 10 03-28-2010 12:54 PM
How do I find a vacuum leak? KeithB123 Engine 2 09-21-2003 11:36 AM
How to find & fix a persistent SBC oil leak jpd37 Engine 16 09-15-2003 06:25 PM
