Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to find pinion angle? 5.3LS into a '37 chevy
Old 04-02-2012, 08:29 AM
spacytracy's Avatar
spacytracy spacytracy is offline
Last journal entry: New neon sign for the garage
x2 with what Matt said. Dont weld the perches until you have the full weight on the suspension. it will mean that you will need to pull the rear out again, but to build your car correctly you will need to pull apart that car multiple times before final assembly. Just go down to china tool aka harbor freight and buy a magnetic angle finder for a couple of dollars to establish parallel angles.
