Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to find pinion angle? 5.3LS into a '37 chevy
Old 04-20-2012, 10:27 AM
evolvo's Avatar
evolvo evolvo is online now
Heathen
Originally Posted by matts37chev
you can get it close
**but for the welding of the perches, i would save it for almost last
because you need to get the weight on the susp.**
it needs to be about the same amount of degrees from straight as the trans
(example #2)
here is a pic i stole from another thread
try the search, i know the are some links to a couple of guides on here somewhere
I'm bringing this thread back to life. The illustration that shows the drive shaft in perfect alignment is wrong. If you where to have that condition and took a long cruise on a smooth road (OK, these don't exist anymore, I know) that didn't give much suspension variance the bearings in the u joints wouldn't roll. If the bearings don't roll they will sit in one position in the caps and Brinnel. http://en.wikipedia.org/wiki/Brinell_scale. This would be especially damaging with an IRS. The u joints won't last long like that. Your much better off using the second example, using 2* to 4* of offset. JMO
