Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to find pinion angle? 5.3LS into a '37 chevy
Old 10-18-2012, 07:08 PM
Razzor1 Razzor1 is offline
Pinion angle
If your using a 8.8 inch axle from a ford explorer 4x4 rear axle you will have a 2" offset from your third member to the center of your transmission yoke depending how long your drive shaft is depends on the degree of offset. It is best to keep a 3 degree or less offset.
