How to find pinion angle? 5.3LS into a '37 chevy
Hello,
I'm installing a 5.3 LS from a 2003 Silverado into a 1937 Chevrolet 4 door. I'm using a Ford 8.8 rear end from a 1999 Explorer. I have the rear end mocked up and bolted in but I have yet to tack in the perches because I don't know how to properly find the correct pinion angle. My engine and transmission are bolted in. Could someone explain to me how to find my pinion angle. I don't want to end up with vibrations. This will be our family car (my wife's daily driver) and we intend to keep it forever (as long as we live anyway), so I want to make sure it's set up as close to perfect as possible. http://i1171.photobucket.com/albums/...7/DSCF5848.jpg http://i1171.photobucket.com/albums/...7/DSCF5867.jpg Thank you, Brandon |
you can get it close
**but for the welding of the perches, i would save it for almost last because you need to get the weight on the susp.** it needs to be about the same amount of degrees from straight as the trans (example #2) here is a pic i stole from another thread try the search, i know the are some links to a couple of guides on here somewhere http://hotrodders.com/gallery/data/5...ngles.jpg?9028 |
x2 with what Matt said. Dont weld the perches until you have the full weight on the suspension. it will mean that you will need to pull the rear out again, but to build your car correctly you will need to pull apart that car multiple times before final assembly. Just go down to china tool aka harbor freight and buy a magnetic angle finder for a couple of dollars to establish parallel angles.
Good advice. Wait till you have the body on and all the weight on the suspension. With the weight on the suspension set your pinion angle and tack the perches in position, then remove the rear and weld them on. Its the best way to set your pinion angle. AND use the second example in the illustration as a guide. The output shaft of the trans and the pinion need to be as close to parallel as possible. Also the trans output shaft should be a few degrees down which means your pinion will need to be about the same angle in the opposite direction in order to be parallel.
Centerline HotRodsAndHemis.com "The only place you'll find a helping hand is at the end of your own wrist" - Joe "Dr. Olds" Mondello |
Ok, thanks guys. That's some great advice I hadn't thought about with getting the entire weight of the car before tacking the welds. I'll swing by Chinamart and pick one of those up.
Thanks, Brandon |
make it look like example #2 not #1 |
Matt, I just went back and read your original post again. I see that you had already suggested the 2nd option, so my comment was not directed at you but at the illustration you used. The fact that they list the first position as "perfect, inline". Whoever did that got it wrong!! :mad:
This all puts me in mind of the Beachboys, I wonder, is there such a thing as a "good vibration"? |
Pinion angle
If your using a 8.8 inch axle from a ford explorer 4x4 rear axle you will have a 2" offset from your third member to the center of your transmission yoke depending how long your drive shaft is depends on the degree of offset. It is best to keep a 3 degree or less offset.
engineering specs
powerrodmike posted this link 5 years ago http://www2.dana.com/pdf/J3311-1-HVTSS.PDF
Last week there was another discussion about drive shafts and posted again. |
| All times are GMT -6. The time now is 05:52 AM. |
