How to find pinion angles - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2004, 04:15 PM
53fordguy's Avatar
Hellbilly Delux
Last journal entry: update after a long time
i havent learmed how, so school me please ford preferable since thats what i have.....
Old 12-11-2004, 04:52 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
it doesnt matter what kinda car or truck you have. this should help you...joe
http://www.chevytalk.org/threads/sho...fpart=all&vc=1
http://www.2quicknovas.com/happypinions.html
http://www.carcraft.com/howto/91758/
http://www.quickperformance.com/PinionAngle.html
http://buickperformance.com/Pinion.htm
Old 12-11-2004, 05:16 PM
pinion angles
face angles must be within 5degrees they can be to one side up or downbut the face must be 5 or less |-------| |---\ nono |
| ok for example i have a 32 ford with 302 and toget a straight steering shaft engine is 1in to the right pinion is centre no vibration at any speed. hope this helps cliff in bc canada
Old 12-11-2004, 05:38 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
http://hotrodders.com/showthread.php...352#post382352
Luv the smell of NITRO in the morning.
