Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to find piston CC? I have measurments
Old 12-13-2012, 04:19 AM
DanielC DanielC is offline
You put the piston exactly 1 inch down in the bore, and then fill the volume with your burette. Measure the volume. Then calculate the volume of a 1 inch cylinder at your bore diameter. Dished piston will read more, domed piston will read less than your calculated volume.
Need this.
Closer view of burette.
