-   -   How to find readend gear ratio on housing of GM S-10 10 bolt. (http://www.hotrodders.com/forum/how-find-readend-gear-ratio-housing-gm-s-10-10-a-132373.html)
Cal Combs 01-26-2008 04:09 PM
I have recorded these numbers & letters off the housing! Around outside perimeter: GM 18 K In middle of drivers side housing: J 29 2 Under that 26027171 N Somebody told me that it is a 3.42 ratio Posi-Traction! Anybody know for sure????????
Vortech 4.3 01-27-2008 10:11 AM
the numbers should be on the gears, not the housing. afaik anyway.
to get a real close #. i mark the pinion and axle/tire. then turn the pinion and count how many times it goes around, to make 1 turn on the axle/tire.
speedydeedy 01-27-2008 10:51 AM
I have 2 S10s and both have 3.42 gears. If you call the dealership with your VIN# they will tell you what the truck came with.
S10xGN 01-27-2008 11:09 AM
This was the only thing worth mentioning from Google. I didn't look through all 6 pages, but the first post has a few listed.
Russ
