How to find readend gear ratio on housing of GM S-10 10 bolt. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2008, 03:09 PM
I have recorded these numbers & letters off the housing! Around outside perimeter: GM 18 K In middle of drivers side housing: J 29 2 Under that 26027171 N Somebody told me that it is a 3.42 ratio Posi-Traction! Anybody know for sure????????
Old 01-27-2008, 09:11 AM
Vortech 4.3's Avatar
jack of all trades
the numbers should be on the gears, not the housing. afaik anyway.
to get a real close #. i mark the pinion and axle/tire. then turn the pinion and count how many times it goes around, to make 1 turn on the axle/tire.
Old 01-27-2008, 09:51 AM
31 five window
Last journal entry: Moving along with patch panels.
I have 2 S10s and both have 3.42 gears. If you call the dealership with your VIN# they will tell you what the truck came with.
Old 01-27-2008, 10:09 AM
S10xGN's Avatar
Gotta love a turbo!
This was the only thing worth mentioning from Google. I didn't look through all 6 pages, but the first post has a few listed.
Russ
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
finding out the gear ratio of a 10 bolt. Super Chevy Transmission - Rearend 2 01-27-2004 08:03 PM
10 Bolt find in junkyards. Madd Syntst Transmission - Rearend 2 11-07-2002 01:28 PM
