How to fit a 429 in Fairlane - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2014, 11:15 AM
xh1gh0ctanex's Avatar
I have a 1963 Ford Fairlane 500 which would like to fit a big block into someday but what all would I need to do to fit a 429?
Old 01-16-2014, 11:56 AM
Wiki Edits: 27
mustang II front
If you install a mustang II front suspension kit and remove the spring tower humps you will have some more space. they make MII kits for 65-6 mustangs I don't know how close those kits would fit google fairlane thunderbolts. they installed 427 FE engines in those. the modifications were done by an outside contractor,, not in a ford factory.
http://en.wikipedia.org/wiki/Ford_Fairlane_Thunderbolt
http://musclecars.howstuffworks.com/...hunderbolt.htm
Old 01-16-2014, 12:26 PM
Yea I know about the thunderbolt I just havent been able to find what all they did to fit it
Old 01-16-2014, 02:56 PM
From Wikipedia "Installing the engine in a vehicle intended for an engine no larger than 289 CID (4.7 L) required major reworking and relocation of the car's front suspension components and the modification and strengthening of the suspension mounting areas." "The Thunderbolt was not built on a regular Ford assembly line, but rather in conjunction with Andy Holten of Dearborn Steel Tubing. It was there that partially built Fairlane bodies in top-of-the-line "500" exterior trim were combined with the 427 and either a heavy-duty Lincoln automatic transmission or a Borg-Warner four-speed manual transmission."
URL for DST is DEARBORNSTEELTUBING.COM Maybe you could contact them and get more specific info.
Old 01-16-2014, 05:40 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Some shock tower massaging not bad for installing the FE engine but rough to install a 429 or 460 then its serious massaging, And get a conversion kit! Consisting of Mts and Plates. Tubular automotive used to sell them for FE conversions years ago. But if your a good fabricator you can use later model mts and fabricate your own mounting plates!
Stock measurements for Fairlane ('62-'63 & Mercury Meteor)
Top of shock tower width: 28 inches
Bottom of shock tower width: 21¼ inches
Framerail width: 27½ inches
Big block measurments '66-'69 Fairlane ('66-'69 Mercury Comet, Montego)
Top of shock tower width: 28¾ inches
Bottom of shock tower width: 25.58 inches
Framerail width: 28.58 inches
Those measurments may help
Jester
Old 01-16-2014, 07:36 PM
techinspector1's Avatar
Wiki Edits: 326
You'll want to become familiar with these folks. Ford stuff only. Click on the left side of the page "'62-'65 Fairlane. Mounts, headers, all kinds of stuff for the swap.
http://www.critesperformanceparts.com/
Old 01-16-2014, 08:52 PM
Wiki Edits: 27
rear suspension
The thunderbolt rear suspension arms were welded to the axle tubes and were for drag racing only . The drivers said they had to brace their left arm against the door to hold the steering wheel hard and keep the car going straight ahead. The early falcolns and fairlanes had terrible bump steer when the front end lifted. A better rear suspension would be to use coilovers-4 link type. I worked for Ford in 64, went into a dealer to order one but didn't have connections.I was told when I hired on as an Engineer in the colleger grad training program I could get a good discount on a new car but the only good prices were on 4 door 6 cyl falcons so I drove my Buick powered Willys to work most of the time. .
Old 01-17-2014, 01:22 AM
4 Jaw Chuck's Avatar
The problem with fitting a 429 into the early Fairlane isn't the shock towers...you could engine plate it in and stiffen the front end at the same time.
The problem is the exhaust, custom block huggers or a custom set of fenderwell headers would be needed...good luck as that could cost a small fortune.
A stroked 351W is a far wiser swap and in the end almost the same cubic inch as a big block with none of the weight penalty. Lots of parts around from the mustang craze and even great AL heads available now from the aftermarket.
Big blocks are great but let's face it, a stroked small block is far lighter...fits where the 289 bolts up and a C4 trans drops into the stock location with the 289 mount plus 1969-70 Mustang headers make the exhaust issue simple. Not to mention any of the late model roller blocks sitting in the junkyards in almost every Ford full size van.
Why complicate your life...unless your loaded and it's a lifetime dream and you have money to burn it doesn't make sense.
— Han Solo
The Following User Says Thank You to 4 Jaw Chuck For This Useful Post:
AutoGear (01-17-2014)
Old 01-17-2014, 10:49 AM
JeffB's Avatar
Or you do it Nostalgia style and build a gasser or A/FX clone like this:
The straight axle will give you plenty of clearance,here is a good example of a build with lots of pictures:https://www.facebook.com/media/set/?...5384103&type=3
Old 01-17-2014, 03:59 PM
Joe G's Avatar
Here is one my friend had built by the Roadster Shop in Mundelein, IL. It falls into the "lifetime dream and you have money" category that Chuck was talking about.
The solution to many of the big block issues here was to put the car on a frame.
Build pics (here)
Old 01-18-2014, 09:26 AM
S10xGN's Avatar
Gotta love a turbo!
You can gain the necessary room by using a kit from RCMotorsports, I've installed 2 now, they are well built and the outfit is awesome for tech support and answering questions. Here's a pic of my Maverick ready for the engine install...
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
techinspector1 (01-18-2014)
Torque converter wont fit 1972 429 johnboy51 Engine 3 01-04-2011 05:16 PM
For God's sake it is FIT, FIT, not "Fitment" when you are talking about panel fit. MARTINSR Off-Topic 52 09-08-2009 08:52 AM
429 and C6 into a 55 Ford Fairlane Rons1stRod Hotrodding Basics 0 03-31-2007 11:59 AM
429 help BrettB Introduce Yourself 2 05-11-2006 04:50 PM
Fairlane 65 largest engine to fit? 65fairlane Engine 1 03-20-2006 04:02 PM
