how to fix - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2006, 12:06 PM
njbloodline666's Avatar
I Love VTec
how to fix
what do you do if you were changing the accelerator pump squirter on your holley 4160 and you stripped the threads... does someone make a bigger screw, also i noticed no fuel comes out without the screw in, is there a check ball inside that stops it, because maybe i can possibly drive this car like this until i fix it.
Old 11-30-2006, 01:36 PM
novajohnb's Avatar
It'll go, or it'll blow...
Bo Laws Products makes a kit to drill and ream out the threads and install a new insert.
www.BLP.com
Whats the list number of the carb (number on choke horn.) May be cheaper to pick up a good used carb body than the kit.
Old 11-30-2006, 04:07 PM
I Love VTec
im not sure of the number, its a newer carb, a street avenger vac secondaries. anyway i ended up taking it to a machine shop and this guy is gonna give it a try. i hope he can fix it.
Old 11-30-2006, 04:08 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Holley's use a propietary screw size. Your machinist needs to know that.
Old 11-30-2006, 04:28 PM
I Love VTec
what do you mean by propietary screw size, is it not a regular 1/4 coarse thread ? well either way, he has the old screw.
Old 12-06-2006, 11:48 PM
I Love VTec
well novajohnb i had my machinist order that repair kit and intstall it... its done, thanks for the help guys
how to fix my screw up blackjackbender Body - Exterior 37 04-14-2006 08:23 AM
How to best fix cracking arm rest Wmarden Interior 2 10-29-2004 12:28 AM
Insane fix for press-fit pistons 87442lover Engine 1 12-16-2003 10:20 PM
Posi-trac Experts (If it ain't broke, should I fix it?) Axelrod Transmission - Rearend 3 05-21-2003 06:23 PM
80' model Vette Fuel Tank, How do I fix a leak? 9.8sec. Hemi General Rodding Tech 8 05-16-2003 07:30 AM
