I understand you don't have the room to do what is shown in this "Basics of Basics" but using the same principles I think you can come up with what needs to be done. Click here
I could build one of those pretty easily. I can understand the constant pressure too. Should I have a helper do this while I gently "ping" the bottom of the dent from inside the fenderwell? Or just use the puller alone?
Thanks!
Russ
