Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to fix this?
Old 02-18-2013, 09:49 AM
tech69 tech69 is offline
put up or shut up
a slide hammer would never get that out. If you don't have a pulling system use your imagination. you need something clamped to the mating flange with a downward puling force. An anchor pot? A steel grate? You can tie it down to somthing strong and jack it up, which will pull out the damage. hammer down any bows or highs as you are giving it the pull. Doubt you can do this without breaking paint. If you want to try first find your highs or bows and tape over the damage, then work it as the tape is protecting your finish. Expect to spot paint.
