Where I live, it's really hard to find body parts that do not have rot.
I've scoured the area for a fender (mine is dented but has no rust), inner fender and hood, and all the ones I've found have rot. All the parts on the right-front of these trucks seems to have rot from battery acid leaks/venting. Also, the coolant overflow tank on mine has a big crack in it that I did not notice until I went to clean it out. acid + water/coolant + steel = rot :-{
I think I'll leave the hood for now and focus on welding the inner fender and straightening the fender. The metal is amazingly hard to bend (lots of compound curves). I've had a terrible time trying to hammer this out, even drilling holes though the inner-layer and using a drift with a socket on the end of it on one dime-sized spot at a time!
I'm going to try heating it with a propane torch to soften it up a bit, and pour cold water on it to re-harden it when done.
