How to fix odometer 1985 Corvette - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2010, 07:28 PM
How can I fix the odometer on a 1985 Corvette I have looked in the books to find nothing on this. Odometer is stuck on 54,900 is it cable or motor or both.Any diagrams would help. Thanks. Bill
Old 09-15-2010, 09:55 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I'm not certain about the Corvette but in the mid '80s GM was using a gadget called a odometer stepper motor to drive a mechanical odometer.
That may be the only thing wrong.
Before disassembling the instrument cluster I would get the shop manual from www.alldatadiy.com
Once you locate the stepper, disconnect it and test it with an ohmmeter to see if burned out or shorted.
vicrod
Old 09-15-2010, 10:16 PM
Vic,you are right, the 85 corvette is the same way. the killer on the corvettes is the disassembly of the instrument cluster, to the OP-be very careful with the cluster disassembly, there are 3 full sized circuit boards stacked and connected together and a full size flexable plastic deal with gold/copper paint to connect all circuits and lights together. PS, change ALL THE LIGHT BULBS in there while you are at it, you will be glad you did.
Corvette electric choke problems JG700 Electrical 5 07-01-2009 07:32 AM
78 Corvette with t-350 bob_robert Transmission - Rearend 5 08-22-2007 10:09 AM
Can I fix damaged corvette door myself? LouisvilleLT4 Body - Exterior 23 09-29-2006 10:44 PM
88 Corvette tpi with Turbo400? wayja Transmission - Rearend 2 05-25-2003 08:37 AM
Posi-trac Experts (If it ain't broke, should I fix it?) Axelrod Transmission - Rearend 3 05-21-2003 05:23 PM
