how to fix a small run "single stage" - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-30-2013, 11:04 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Meguiars makes a little "stone" block that's 1000 grit.
Works great on wet sanding runs.
It's completely flat and rigid, you can feel it when it's on
the run or when it's not.
It's about 1.5" x .5", works great.
  #32 (permalink)
Old 07-30-2013, 11:21 AM
That's the only "tool" I use on anything like that. I don't like the "files", I have had great luck with the "stone". True it on a piece of glass with sand paper on it once in a while and it's as good as new. They have them with other grits too, 1200, 1500 is as far as they go I believe.
  #33 (permalink)
Old 07-30-2013, 11:47 AM
Something similar to that, which I have been using is a very small peice of plexiglass about 2 inch by 3/4 inch that is hard and rigid as it will only sand the high spot of the run. A lot of the time you can still see the outline of the run as a small ripple, using a hard FLAT block will eliminate this.
single 3" too small screamin67 Engine 2 11-29-2011 08:20 AM
Help with a single stage run dirtracer8c Body - Exterior 7 05-21-2011 05:04 PM
How do I fix a run in black signle stage? shad9876 Body - Exterior 3 07-16-2008 11:59 AM
"we fix $20 tattoos" sign at the ink shop left me wondering .... lowROLLERchevy Off-Topic 11 06-28-2008 05:45 PM
Buffing Out Single Stage Paint "From a Production Shop Perspective" x711 Body - Exterior 18 12-28-2006 10:27 PM
