Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to fold corners with vinyl, help please!!!
Old 04-19-2013, 07:09 PM
JZG88 JZG88 is offline
Originally Posted by DanTwoLakes View Post
What kind of glue are you using? The best way to do the ends and get the excess fabric out of the way is to cut a piece that matches the end and sew the two pieces together. Then you are cutting the sewn in piece and not the larger middle section. Then if you make a mistake you are only replacing the small end section, and not the whole dash.
For the ash tray hole, cut a horizontal line in the middle about 2" long and then four angled cuts up towards each of the four corners. Fold the fabric onto the back side of the dash and glue the vinyl down. Then just put the ash tray back in to hold the vinyl in place.
Oh, I'm using "Heads up super duty interior adhesive" It works well for the larger areas but lifts up around the curve edges a little, I'm gonna go to Home Depot to find some liquid glue because the spray adhesive gets every where when holding it 8 inches away as recommended. Is there something better out there that I can use. Oh, and I'm gonna try to make door cards when schools ends this summer, What type of adhesives work best on foam, vinyls, and masonite? Yea, Ive never sewn anything in my life, so I'm probably just cut it in the middle and fold it over, lol.
Thanks for your advice on the ash tray now that doesn't seem like something I can screw up, but I can surprise myself sometimes, hahaha..
