http://www.hioutput.com/tech/400hp/400hp.html
as far as the formula goes, that would be a tough one. |
how bout theory???
I mean I know we've all heard the claim that 1 CI = ~ 1HP,,,, Right????
Were did this come from considering a stock 75 truck 350 made what mabey 250-275 max (just a guess), But just a few years earlier GM marketed a 375 horse 327ci, or was it 350 horse?? either way it still beat 1:1, what all was different. cmp ratio, cam, heads, intake, carb, ect.. but where's the balance. Edlebroc is claiming they have a dyno tested 350HP 350 SBC crate motor. Now assuming those numbers aren't exagerated and it really does make 350HP, could one use this as a base to go off of for a 1:1 ratio... Obviously variables will change based off the size of the engine, but shouldn't the same concept be able tro be used with some simple arithmetic????? Please get involved, 500 brains are better than 1, or 2, Thanks |
It is easy in engines smaller then 350 as well. There was an article of a 318 build to 400 something hp and I got shop plans for a 380 hp 318. There is alot of meat in these smaller engines that can really be opened up. If you like I can show you some for the 318.
WWWAAAAYYYY over my head
Thanks man but that was way over my head, I was talking more by means of simply adjusting the CR, cam specs, cylinder head flow, induction sys. ect, ect... any other thoughts that I may be able to comprehend??
My mother's cousin is a long-time drag racer in Houston. I remember when I was in high school he said, "It's pretty easy to cheaply get 1 horsepower per cube. Get too far above that and you'll have to start spending cubic dollars." One of my favorite sayings.
Hi,
!969 -70 Corvette optional engine L46 a 350 CID 350 HP 380 # ft TQ, the 11-1 CR & cam is what got it to those specs Rich |
The best thing you can do with all the engines you have sitting around is just build one with the best of what you have, get it in a car, and race! Don't get me wrong it's good to research, read, and theorize but one pass down the track is worth more than any single book or formula. Breaking stuff is the best way to figure out what doesn't work, and sometimes you'd be surprised what "junk" will do. Dynos, like flow benches, are valuable TOOLS, but that's all. In experienced hands they can help an engine builder develop that last few HP. Without track time it's almost worthless! You don't race on a dyno. Don't get hung up on this stuff... Get out there and race! It doesn't matter if all you can afford is a 305 with Vortecs, getting to the track and tearing it up is the best time you can spend to learn what works! You will also get a chance to see folks that make engine scream for very few $$$ and LOTS of cars with $8000 engines that should be embarrassed to come off the trailer! You might make some Friends that will help you more than anyone on the internet ever could. I haven't sold a "take off" part in ~10 years, but I've given away LOTS. Really, get whatever you can in a car, put a drive shaft loop and rev limiter on it and go break some stuff!!! |
eatonde,
no it can't be "simple arithmetic" because different motors have different bore and strokes (ratios) which changes the piston speed (feet per second) per rpms and hense, the inhaling capability for the cylinder with a given camshaft.... ex: the speed parts combo that yeilds 1HP per cube on a short stoke Ford 289 (at about 7000rpms+) will be different than the parts for a longer stroke 351W to reach 1HP per cube (at about 5000rpms) even though they both have a 4" diameter piston.... the 250HP 350 truck motor is "purpose built" to make the max max max possible very low rpms TQ force per rpms per cubes for acceleration power from a red light with a heavy vehicle by getting the best fill possible when the pistons are moving too slow...."TQ" is the must have priority due to the weight and 250HP at 4800rpms is a reasonable HP amount for passing somebody (LOL, if you do downshift) when a vehicle is already moving.... maybe the best/smartest way for you to understand all is put a "Desk Top Dyno" software program on your Xmas gift list???? it has "oem look up tables" for whatever motor and does the heavy duty math based on a given parts change you entered to calculate a gain or loss on all the operating variables for making HP.... as with any software program:"garbage in = garbage out results" so you do need to be very careful entering all the specifics and variables to get a "close to real world" result!!!! dang CRS!!! a well known speed parts mfgr does have a very very crude "Desk Top Dyno" program on their site that you can play with to get the idea.... LOL, give me about 3 days and I will recall which site.... Last edited by red65mustang; 10-31-2008 at 08:44 AM. |
There is no math to it...except subtraction from your checkbook.
Buy a ZZ4 shortblock and an Edelbrock RPM air gap top end kit, Holley, 3310-3 Msd billet and 6al. 410 hp out of the box every time. Be ready to do a bit of tuning on the carb as this kit breathes fire just off idle. I have one and love it. If you really must have 1.25 just spring for the RPM roller cam.... 438 hp |
1.25
well I was just listing the engines I currently own before. The one I really want to try to get 1.25 per cube out of is my 400. 500HP out of a SBC 400 should be that hard, should it.
I know the majority of the power is gonna come from the heads. A guy plugged the current engine specs in for me to DD and it said 293 HP @ 4000 410 FTLB @ 3000 This was with the stock pistons, comp 268H cam and 882 heads. I have a set of vortecs that will take the CR 10:1, But I'm afriad the cam will be to small for that CR.... I'm also buying a set a patriot's 190's so I dunno which I should use |
Stop putzin' around with junk and get stuff that works. No guessing. Already done for you. Here's the combo....
Horsepower: 572 @ 6000 Torque: 536 @ 5000 Engine: 406 Chevy Heads: AFR 210cc competition package Intake: AFR Street Pro-Flow RPM #5028 Compression: 10.1 Carburetor: 750 Ignition: MSD distributor 36* Cam: Lunati hydraulic roller 242*/252*, 0.560"/0.572", 112* Exhaust: Hedman headers 1 7/8" Fuel: 93 octane pump gas Here's another with a little less hp, but a little more torque.... Horsepower: 551 @ 6000 Torque: 540 @ 5000 Engine: 406 Chevy Heads: AFR CNC Cyl. Heads 210cc Race Ready Intake: AFR Street Pro-Flow RPM #5028 Compression: 10.3 Carburetor: 750 Ignition: MSD HEI Billet Distributor 36° Timing Cam: Lunati Hyd. Roller Cams 232°/242° 0560-.570 lift W/ 1.6 Rockers Exhaust: 1 3/4" Headers Fuel: 93 Octane Pump Gas Even the 195 AFR heads will make over 500 hp on a 406. Last edited by techinspector1; 10-31-2008 at 03:00 PM. |
well tech that sounds great, but I don't have the money to be buyin all that stuff.
Since when are GM vortec or patriot heads JUNK???? I don't think that a set of Patriot freedom's 190's CNC bowl blended, fully assembled with quality components and .600 lift springs is junk at all flowing 263cfm @.500lift. But if you wanna foot the bill for me I'll be glad to build it |
| Warlock bypass mufflers | 70bird | Engine | 9 | 09-24-2008 08:53 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Horsepower | jbvcw71 | Engine | 11 | 09-02-2008 02:00 PM |
| I need intellegent input concerning HP ratings. | glen242 | Engine | 24 | 05-22-2008 05:56 PM |
| 260 HP or 290 HP GM Crate motor | Iceberg | Engine | 4 | 02-26-2005 01:26 PM |
