Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to get a Chevy 302 under 10:1 CR
Old 01-20-2008, 08:21 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
If it is a 283 block it will be 2 bolt mains and small journal, you can verify with casting #'s what the block is. For compression I second all the comments about heads, it also gives you much better porting which could offset any loss of power from the cmpression drop. By the way , punching 283s to 4 inch bore was a pretty common trick, they were called 301s at the time. We used to do them regularly when I worked as a machinist. The 302 crank is also forged, not cast, the 2 have entirely different seam lines.
