Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to get a Chevy 302 under 10:1 CR
Old 01-20-2008, 07:42 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
What you probably have is a 327/350 block with a 4" bore. If you really have a 302 crank you have something super special, those cranks are nearly impossible to find. The crank alone is worth a ton of money. You can confirm the block casting numbers and even the crank number at Mortec.
The small journal 265/283/302 cranks were 3815822 (302 was 1967-68)
The medium journal (400 is large journal) 302 cranks were 3941178 and 3923279 (302 was 1969)
Vince
