how to get flames to come out of my tailpipe - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 07-30-2004, 11:44 AM
BuickLeSabre1960's Avatar
Last journal entry: Flamethrower trial
Re: Flame throwers
Originally posted by Nomadci
I installed a flame thrower system on my Choptop 54 with an independent fuel source in the trunk. The smalll tank 2(quart) goes to a 7psi fuel pump and from there to a NOS solenoid where the tap is 'T' connected to the dual exhaust about 6 inches from the tips. I have spark plugs installed in the tail pipes which are ignited by a toggle switch on the dash. Actually there are 3 switches 1 toggle for the fuel pump, 1 for the spark ignition and a momentary for the solenoid. I currently burn kerosene and get flames in excess of 20 feet. To see the set up go to cardomain, chevrolet, belair, year 1954 and you'll see the car....I also installed a backup camera so I can see behind me before I hit the switch.
You seem to know what your talkin about so i'll ask you, I'm going to be putting an injected kit on my car(look at pics.) but my car has bellflower tips on it so I can't put the injectors and spark plugs in the pipes less than 30" from the tip without them being seen. Am I going to have to do it where you can see the parts?
  #62 (permalink)
Old 07-31-2004, 04:23 PM
The problem is the metal...the exhaust pipes become red hot after you hit the flame throwers a few times. Which is why it is highly recommended they be at the tips of the pipes. Given your setup could you put them on the inside of the pipes and make your connections through a fabrication in the trunk? By the way your car looks great!!
Damon
  #63 (permalink)
Old 07-31-2004, 05:35 PM
I don't quite get what your saying about putting them in the pipes. Put the injector in the end of the pipe and run the connection into the trunk? thanx, I just got it a few months ago. Got any pics. of your car with the flamethrowers goin??
  #64 (permalink)
Old 07-31-2004, 08:23 PM
If you can send me several pics of the rear exhaust from every available angle including inside the trunk, even though you may not be able to see them from the trunk......I'm assuming you want the hardware as concealed as possible. I'll send you some on fire pics in a couple days.
  #65 (permalink)
Old 08-01-2004, 08:03 PM
I'll get the pics. tomorrow. because of where the tips go in at on the car the pipes actually go in the corners of the trunk.
  #66 (permalink)
Old 08-03-2004, 05:45 PM
Here's the outside close-up
  #67 (permalink)
Old 08-03-2004, 05:48 PM
here's one looking down the pipe
  #68 (permalink)
Old 08-03-2004, 05:51 PM
this one's the right side trunk
  #69 (permalink)
Old 08-03-2004, 05:53 PM
this's the left side
  #70 (permalink)
Old 08-03-2004, 05:55 PM
here's the under side on the left
  #71 (permalink)
Old 08-03-2004, 06:08 PM
421Bonneville's Avatar
Old car nut (me & the car)
Two bowls of 5 alarm chilli followed by a couple cold ones ought to do it.
  #72 (permalink)
Old 08-03-2004, 06:20 PM
one more pic
Thanks a lot for the pics...I need one more though...a pic from the bottom looking up so I can see the pipes in relation to the body and bumper.
Thanx
Damon
  #73 (permalink)
Old 08-03-2004, 06:42 PM
ok, here it is
  #74 (permalink)
Old 08-05-2004, 07:15 AM
Well it looks like your best bet would be coming from the bottom rear of the pipes. If you can angle them (injectors, plugs) slightly they won't be as visible. The more difficult option would be to come from the inside of the trunk which would involve cutting the trunk to expose the area of the pipes for the injector and the plugs. Either way you have some work ahead of you.
Damon
  #75 (permalink)
Old 08-05-2004, 04:04 PM
What kind of injector should I use, and is there a difference in the look of the flame between gas and running a seperate kerosene tank? I don't want huge flames (about 10') and I want them to be the rolling red/orange. Where in Atl. do you live, I just moved from there a few months ago.
