how to get mouse smell out of truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2012, 11:22 AM
Last wiki edit: Mounting an electric fuel pump Last photo:
I recently bought a 87 bronco ii from a friend. Its ben sitting for a year or so and had enough mice living in it to have a grass snake turn it into a permanint home. Found severl compete skin sheds and since its winter, its prob still ridig around with me lol. But im wondering if theres any tricks to getting the smell out of the heater and seats. Dealing with old hotrods, im sure someone here has sum advice
Old 01-06-2012, 12:09 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Fabreeze air freshener and the little sheets from the wifes laundry dryer in the heater vents until you can pull out the old nasty carpet and redo the seats..
Sam
Old 01-06-2012, 12:43 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You'll have to strip the interior and get rid of any cotton, burlap, insulation, carpet, and cloth seat upholstery. Mice will have been in all those places looking for nesting material.
I did a '49 Packard, and under the entire passenger side of the headliner from front to back the mice had packed it full of seat cotton and insulation. It was the biggest mess I've ever seen, including a spot by the front pillar that had mouse urine stains that went from the headliner all the way down to the dash.
Old 01-06-2012, 01:52 PM
Anyone know how hard/simple it is to remove heater core and if id be able to clean most of the ducts from there? Its the same as late 80s ranger.and thanks for the tips. Realy not wanting to pull everythin tho bc i bought it s i could park my "hotrod" and use the bronco as a d.d.
Old 01-06-2012, 07:02 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
Hate mices to piecies
If it' s as bad as you say then everthing has to come ater ut . Its not too hard to pull heater case.[ be glad its is not a 69mustang] Water/soap/ lysol will conquer
Old 01-06-2012, 10:35 PM
Well today i pulled the blower and found very little but remembered i had sum axe spray in my truck so i gave the ower a good soaking b4 i put it back together. I then sprayed quite a bib into all the vents and used the rest of the can on the seats and carpet. Its sitting over night to air out. Im hopeing it covers it up for a while till i have time for a good clesning.
Old 01-08-2012, 02:05 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
My brother got a old ford from my dad years ago that had a mouse smell he pulled it apart a hosed everything down good, let it dry , put it all back in and on hot days the smell would come back. Almost impossible to get rid of.
Old 01-08-2012, 02:17 PM
Lotsa' coffee grounds all over the interior helps! Keep the windows/doors closed!
Old 01-09-2012, 04:55 PM
Well just an update, its ben close to a week now and the axe has worn down but the smell hae not fome back yet
Old 01-09-2012, 04:58 PM
poncho62's Avatar
Wiki Edits: 5
Spring and warmer weather will likely judge whether it worked......Smell is very hard to get out of fabrics and the padding under it
mouse smell swvalcon Interior 18 03-14-2012 08:11 AM
How do I get rid of mouse smell? tsummers Interior 9 09-18-2009 03:51 PM
400 Mouse Motor Hustles365 Engine 5 05-24-2008 03:34 PM
spam in "Mouse Smell" post TooMany2count Hotrodders' Lounge 1 11-06-2006 07:09 AM
Mouse Previews AngliaBob Hotrodders Site Suggestions and Help 5 08-02-2005 04:32 PM
