Takes a lot of patience. I did this with my polished stainless, soft rag with slight pressure by hand, keep rubbing and pulling on the tubing (sounds very dirty). Where it keeps curving, put the pressure opposite and rub it out. If it starts curving the other way, you have put too much pressure.
Maybe I shouldn't have said anything, but that works well.
I just buy the lines straight.......and put the bends and curves where I want them.....
Car Quest Auto Parts has the tubing in 72 inch lengths....NAPA and most others only go the 60 inches....
im sure i can get them locally .. but you're too far from me .. just metter of looking around... but if you can post a picture too see how are they now maybe i can more helpfull giving idea on how to straight the ones you have now
Roll it out. Grab a stool or shortish chair and a pair of rubber soled shoes. Straighten the line as much as reasonably possible and lay it on the floor. Put one foot on the straightest part and roll it back and forth as you might a pencil lying on the floor. Use the other foot to work the really bad sections until the entire line will roll back and forth nice and smoothly. Sometimes it takes a while.
you need to take your time and try to bend it by hand. be carful not to kink the line
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
