How good are pro comp cylinder heads - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 10-15-2012, 07:26 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Why was it back when we made everything here and bought the things WE made a man could have a decent paying job and things where affordable... **** went to hell in a hand basket when we started importing all this crap and sending jobs overseas.
  #47 (permalink)
Old 11-16-2012, 04:17 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
me 2 cents I purchaced a set of procomp oval port 300cc aluminum heads pro comp layered gaskets and proconp studs for aluminum headsfor a total of $1150.00 including tax from ASA in COLUMBUS GA add said completly assembeled opened package today to puy on my BBC engine they are NOT together have to put on guide plates and studs problem is bolts for studs are7/16, holes in heads 4 are 7/16 4 are 1/2 holes 1 head came with helicoil but they dont fit the holes 2 guide plates do not align with pushrods the set at approx 30 degrees so i am going to have to remove heads redrill tap and helicoil both heads so rocker studs will fit i will loose layered head gaskets 70.00 plus labor sealer and antiseize trial fit intake after problem with heads you guessed it, intake does not fit some of bolt holes are off 1/2 of the hole this is a factory GM tripower intake so i cant enlongate holes with runing value of intake approx $1200 just incase anyone cares I AM NOT HAPPY, Dont wast your money
  #48 (permalink)
Old 03-01-2013, 09:26 PM
I got some cnc AVG/PC 351C A3 port heads for $1900 complete, really nice castings, really happy with them, looking to buy another set right now.
  #49 (permalink)
Old 04-22-2013, 04:32 PM
El Rob's Avatar
is it me r does the rocker arms not look right.
Yes i know this is over a month old
  #50 (permalink)
Old 04-22-2013, 06:40 PM
Proud LOSER
Their right if your installing them on a lumpy old ford motor....cleavland style....
  #51 (permalink)
Old 07-04-2014, 01:15 PM
Sundance7055's Avatar
I have the same heads on my 383...the problem with these heads are there is too much meat inside the chambers witch block the flow...check it out you'll see...I saw a video on you tube that dealt with this problem
  #52 (permalink)
Old 01-09-2016, 02:00 PM
1st gen procomps
I know this thread is really old but i want to add to this procomp debate with my actual history. first a little on me. I am a process engineer. i started out at the bottom as a machinist running a drill press or handscrew. i was smart and soon was running CNC lathe and mills. because i am fairly smart i kept right on going and now i am figuring out how to process medical instrument and implate parts thru a machine shop, send out to passivation, plating, silk screening what ever is needed. i know parts and machining. casting everything to make a chunk of metal in to a beautiful instrument that will possibly save a life or make it better. NUF said about me.
I'm just building a SBC 350 (355) for my 65 malibu SS. I like to play and do everything so my car is set up for street, strip, autocross, whatever trouble i can get my self in to. I first bought a set 1st gen 190cc, straight plug, 64cc chambers, 2.02/1.6 heads, complete off ebay. the casting core shift was horrible on the intake runner of 1 head. bad enough to where the center port dividers only overlapped the head by .03 and i didnt think it would seal and sent them back. aside from the casting core shift the machining looked superb. all threads and milling look great. nice finish everywhere. the intake ports were very small on these 190cc heads. smaller than my "461" camel back heads. because of the core shift and me sending them back, the seller let me exchange/upgrade to the 210cc intake, angle plug, 64cc chamber, 2.02/1.6 heads, set up for roller cam (i did not know these werre raised runner intake ports). these heads were much better. again the machining looked excellent, all threads were nice, all milled surfaces looked great. there are very large casting ribs in the intake port in two places. 1 is by the push rod and the other is closer to the bowl end around a head bolt between the Siamesed runners. the distance cross the opening by the push rod was smaller than my 461 heads because of the casting bulge. i figured "aluminum casting" and that these were supposed to be ported, so i did just that. i also checked the valve seat to guide runnout and all the seats were within .002 except for 3 seats were .003, .004, .006. i feel this is pretty good considering 16 seats. i have had fresh heads out of the box on "American" made heads that had seats up to .015 out of whack so this wasn't to bad right out of the box. I like to see less than .002 so i corrected the three seats. all the exhaust seats were within .002 right from the start. also, the intake port is a raised port on these heads so it doesn't work with stock gaskets. you need the larger and thicker felpro 1266 gasket. a 1206 will not work it is too thin. I gasket matched a Vic Jr intake to the raised port head. an RPM air gap didnt have enough meat to do this, at least the one i had looked at. after porting the intake runner out as far as i felt safe without going to thin and breaking thru i still had some small casting humps but it is way more open and the raised intake runner is supposed to help make more power so i dealt with the extra porting of the intake. i installed the heads on the motor using the procomp parts as i was short on money and time and figured i would upgrade the parts after the summer of driving. the engine ran like a raped ape. i have a howards oem style roller cam p/n 180265-10. paired with 1.6 rockers it is .565 lift int/ .581 ex. final lift. so far the heads are kicking as. i raced a buddy with a 409 sbc with Dart heads and he dynoed at 498 hp 502 tq and its in a 74 buick apollo with the same 3.73 rear gears i have in my malibu. we raced and we were dead even so im assuming im making close to his power with a 355 cid engine. not bad at all.
after this summer ended i pulled the heads off and inspected parts. all the ends of the exhaust valves were beat to ****, looked like they have been actuated by a chisel & hammer. some of the valve tips had little chunks of metal chipped out of the edges and the end surface looked horrible in general. one intake valve also looked like this. I was also running some really crappy KMJ stainless steel full roller rocker arms. DO NOT BUY THOSE THEY ARE JUNK. the roller tip is not perpendicular with the rocker trunion so the roller tip doesn't contact the valve tip squarely.
Back to the heads, the seats and castings still look great after beating this motor about 4000 miles this summer. i am now installing manley valves, crower springs, comp cams ultra pro magnum full roller steel rocker arms.
i could have bought the heads as bare castings and looking at this with hind sight, thats what i should have done. i think the bare castings were around 350.00, add the 300.00 for new manley valves and crower springs, & stem seals i would have been right around the 650.00 i paid for the complete heads with crappy parts. i know procomp is now speedway and i heard they have improved quite a bit. so i would tell you i am very happy with the heads but not the parts installed in the heads. the new speedway heads might be better. i could have saved a lot of money if i would have bought bare heads. with that being said, even after upgrading the valves, valve springs, valve guide seals, plus add gaskets i am still LESS than the cost of a pair of complete "American" made heads. total cost is sitting close to $1000.00 after all the upgraded parts are added in. So Mrperformanceparts is pretty much right on the money. you need to ask, or build it your self so you know what parts are in your heads. then you will have no worries.
  #53 (permalink)
Old 01-13-2016, 09:21 AM
PHWOARchild's Avatar
Speed Master sells a lot of Pro Comp parts, maybe they own them? I see lots of their rockers sold by KMJ, total knock-offs of any rocker under the sun. Both Speedway, Summit and I'm sure Jegs and others sell as well.
I looked at some other aluminum heads (Flotek) sold by Speedway and was steered away from them by my engine builder. Cast in China, machined & assembled here.
I wound up with Dart aluminum heads and intake, Lunati cam, lifters and roller rockers. Push rods are from Comp Cams (bought locally).
My thoughts, build it once and build it right. I tried to use US made components everywhere in the build.
  #54 (permalink)
Old 01-13-2016, 11:50 AM
kso's Avatar
kso kso is offline
i are really smart too i believe. Some say different however. Whew, now that we've got that over with... There are guys who go buy a well-engineered, well-made and pricey item, take it to China or India and say "make this"...whether the manufacturer knows what they were making or not, a shipping container of copies comes back and is on the market here looking just like the original. It's a good way to make a buck, I know or know-of a couple people who do just this. In many cases it's necessary and fair, such as for reproducing a no-longer-available part...in others it's just a blatant rip-off of the original mfr. effort. Hopefully for the sake of the end user they at-least get the quality right, but in any event I try to not support people doing the latter.
That said, the worst-made (design, casting and machining) part I've ever bought was from right here in the USA from a company calling themselves "the greatest name in racing". It was a long time ago but I never forgot dropping an intake manifold that cost me a week's wages into the scrap barrel when I was finally fed up with it. So it's not like you can just rely on anything...or not...based on where it came from.
  #55 (permalink)
Old 01-13-2016, 03:22 PM
hcompton's Avatar
Old & Furious
Pretty much no gm heads are patent parts. Everyone steels from gms original designs which are often just as good or better than the copies. No one complains when edelbrock makes a copy of the gm vortec racing head. Not sure why everyone jumps on the china stuff they never cared when us companies did it. But for the record procomp is made in china because of free import tax. If they made them in Austria or anywhere else they would have to pay a heavy import tax. Blows but that how it is. Some companies like speedmaster/procomp even make parts elsewhere and import them to china and back here so they dont have to pay inflated taxes.
Speedmaster has always been the procomp parent company. That is there aussy trade name.
I like the procomp heads I got. They look good and work good as well. they could of course use some porting when not cnc version. But hey there cheap I can port instead of paying top dollar for a set. And with any large port head there are some different setup requirements. Gaskets and port/rocker alignment. The large port brodix and afr both require offset rockers and lifters. Now some afr work with standard sbc stuff but not all of them.
I have never understood the bad rep procomp gets on the internet. The other companies making there heads in china never get the same treatment.
Make sure you get the rockers on right or they will beat the new valves as well.
  #56 (permalink)
Old 01-14-2016, 08:49 AM
I would think that companies like Edelbrock would pay a royalty or at least get permission from GM or whoever to make parts based on their design.
But the total knockoff industry has no R & D or engineering back up on anything they produce. Do they do testing, run FEA on anything they make? I tend to doubt it.
I make lots of knockoff parts myself, I'm sure many of us do to suit our needs. But we don't try to market them.
  #57 (permalink)
Old 01-14-2016, 09:43 AM
hcompton's Avatar
Old & Furious
Nope they just make them. GM does not sue them and they have gotten away with it for so many years at this point i dont think they would win lawsuit if they tried. afr has actually helped gm with some of there stuff.
Lots of companies design there own heads and stuff but its all based very closely on gm designs. In order to get a patent on a head it would have to be 25% different from any previous patent. Since thats pretty much impossible. there are not to many real patent parts made in this field. Edlebrock and the other big guys had an advantage as they owned the foundry but its cheap to buy an un-ported casting now a days and bang your a head manufacturer. For the most part they just pick there port and chamber size and machine the bolt holes and other machined surfaces.
Since there are only a few really large foundries in the world that can cast a block or head from aluminum you can imagine that many of the companies buy there castings from the same place. why one would get a bad rep and the others a pass is beyond me. Pouring 50 pounds of aluminum to make a heads is no small feat and not going to be done by a small business in the us or anywhere else for that matter.
Even the larger companies buy castings. Part of the deal with the castings is you take responsibility for there construction so legally you are the manufacturer but in reality its just paper work and none disclosure agreements. From cell phones to tires many things are made this way today and is one of the ways we get such a diverse list of parts for high performance engines.
If you look at all the head designs for a sbc and then look at all the heads made by gm performance you will see there are no really new designs. Gm has a 9:1 compression head that will make almost 800hp for class of nascar racing. Has had them on the market for 20 years. commonly called the 18 degree head now a days many companies sell a version of this head in different combos. 15 and 12 degree are mostly the same head angle milled to produce the valve angle. Where the raw 18 degree casting is a breed all its own and makes a lot more power than any 23 degree head. It is still a gm designed head and in some cases made by gm.
I for one am glad gm did not fight the aftermarket cause that led to all of us having so much fun. Gm could have been the only seller of sbc heads and thats ok since they have lots of good choices but the cost and limited parts would be hard to work with. nothing like todays aftermarket tech. but in fact every major advance in sbc was born at gm 30 years ago. from roller to LS heads they designed them all and its awesome you can buy from so many different companies and combos on the market.
  #58 (permalink)
Old 01-14-2016, 03:19 PM
X2 that's pretty much the way it is, aluminum casting especially complex castings like heads and blocks is not a mom and pop business. It takes a huge investment of finance and foundry technology to pull this off before you even get to refined or unique port and inlet designs and finish machining. This kind of foundry work has largely left the U. S. of A because it is a messy business that causes or results in a lot of pollution that the greens don't want. So the cost of clean up is out of sight. Your electronics is the same way everything from the circuit board to chip manufacturing includes a long list of chemicals you don't want in your neighborhood. My guess is the Chinese goverment just lets this stuff run on the ground in the desire to acquire western technology while the American companies that relocated there get to enjoy cheap and easily replaced labor with no environmental clean up costs; a marriage made in heaven. I don't see this changing anytime soon.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
AutoGear (01-15-2016)
any body heard of pro comp heads for ford small block mustang joe Engine 2 07-10-2007 09:34 PM
pro comp 190 heads chrismac Engine 4 06-08-2007 04:56 PM
Eq Lighting Cylinder Heads Rogers Performance Engine 18 09-25-2005 12:40 PM
Are TBI Heads Good??? stereodud Engine 8 01-01-2003 07:31 AM
