Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to ground a compressor?
Old 11-28-2009, 07:50 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The receptacle you are showing is a 30 amp 125/250 volt 3 pole 3 wire. It uses two hots and a ground. It would also be wired with #10 AWG wire. As stated you need to verify the max amps your compressor requires.
Vince
