Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to handle this (pictures inside)
Old 01-07-2013, 08:39 PM
John long John long is offline
Every ones advise above is good. One thing you can do is take tubes of Epoxy cement and mix them with fiberglass cloth cut up into small 1/4 inch slivers. Add the slivers of fiberglass to the epoxy cement until it becomes a paste and apply that instead of body filler. It is significantly stronger than the body filler and will take a little longer to begin to bubble. It WILL NOT give you a permanent fix. Just last a little longer.
Do not use polyester resin. It is not strong enough. Use Epoxy cement or Epoxy resin only.
I hate to admit it but I did this in the 70's as a 20 something year old and got a few years out of an old Merc I had.
John L.
