How hard is it to install a vinyl top on a hardtop car - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2007, 07:20 AM
I have a hardtop car that I would like to install a vinyl top on, are vinyl tops hard to apply? It seems that they would have to be pretty tight.
Old 08-26-2007, 09:47 AM
I've put a few on. It's easy in my opinion.
You use a contact type glue, ours says "Landau Top Adhesive" on it.
So you let both sides dry and then put them together. It's important to mark the center and get that section glued first, front to back. Then work towards the sides. You can heat and pull the C-pillar area if needed.
Larry
Old 08-26-2007, 03:49 PM
I'm assuming the top has to be bare steel right? Is there any way to shift the vinyl to get it straight after you first adhere it. What type of prep work is needed before installing the top?
Old 08-26-2007, 03:59 PM
BOBCRMAN@aol.com's Avatar
Not a job for amatuers. You finish the top surface just as you would for paint. Any bare metal will invite rust under the vinyl. You will need more than one person to help you lay the prepped vinyl down. Once it touches IT IS STUCK!!!! no second chances..
Several others and myself have left instructions, check the archives.
Old 08-27-2007, 07:40 PM
Thanks for the info guys, I'm not positive if I'm going to tackle it or not just thinking ahead.
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 03:53 AM
POLL: What color for vinyl top on this car....SEE PICS.. STATUTORY GRAPE Body - Exterior 8 02-23-2007 08:04 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
Repair/replace Vinyl top? Jehannum Body - Exterior 5 08-22-2003 08:45 PM
best paint/ prep to put under a vinyl top novajohnb Body - Exterior 1 09-05-2002 08:16 PM
