I had a 67 cameroSS with a very rare steel, small J. 3.48 crank... The local hot rod shop had never seen one...
The thing is ,is that it was built with old fasion cast 11 to 1 pistons,low tech bottomend.
The heads were another matter..
461's 1.94 by 1.6 Fully Ported by a very famous guy here where I live-
for cam I put in a crane blueprint L-79..
With a stock Q-Jet manifold and a Holley 650 spread bore D/P (4 speed trans!)
This thing would snap u-joints.The driveshaft was bent before I had a chance to put slapper bars on it... I allways considerd it to have 350 to 375 easy HP ...??? is-How Hard Can You Push (with good heads etc) a basically stock,cast piston,crate short block-
I Know that this is a "up in the air ???" but come-on give it a try...
Thanx Don
Thanx Don
